Which Mid-End card?
BlackTigers91
Sooner rather than later, I'll be building a new rig. I have budgeted $200ish for a videocard.
Here's the perspective Cards:
x850xt
7600gt
USED 7800gt :)-/)
6800gs
This will be paired with an OC'ed Venice 3000+ (939). Now I was wondering, what would you do. If I get either the 7600, 850, or 6800, I can also pick up Oblivion :)
I don't wanna hear:
Well you can just OC the x850! Well, buddy, I can overclock the others, too ;)
nVidia is t3h suxzorz, ati ftw!
WWUD?
A used 7800gt will give far better performance than the other 3 check on Newegg for a refurb (most of the time refurbs are just cards people return cause the got a pcie card for an agp mobo or something similiar) fs/ft forums should also yeild good results.
Agreed!
plz tell me where you can get a used 7800gt for 200 becusae newegg refurbished the highest is like 300.
o well where do es it say a 7800gt for 200 dollars because thats a unbeliveable deal even used
Ya rly, get a used 7800GT. It was only released about a year ago so it probably won't die on you for at least a few more years, since when you get an old card the thing you're worried about most is having it die on you.
