which MB
pinktri
was wondering which MB do you guys recommend for a opty 170. I currently have a MSI K8N Neo4 Platinum SLI but also have a ASUS A8N-SLI Premium on it's way. I won't be able to test both at the same time because one of these MB will be going to a friend the day I receive my ASUS. Which would you guys use for OC and stability. Here's my setup:
-OCZ 2GB (2 x 1GB) 184-Pin DDR SDRAM Unbuffered DDR 400 (PC 3200) Dual Channel Platinum System Memory
-74GB Raptor, seagate 400GB SATA 7200.8
-Antec power supply (I believe it's 480W)
-eVGA 7800GTX
thanks for the help guys
