which mb/setup?
SBMongoos
Time to shop for upgrades.
Here's what's on my wishlist and I'm looking for feedback/thoughts.
Gigabyte GA-8KNXP Ver 2.0/Intel P4 3(e)ghz-800fsb/2x512 DDR400 PC3200 RAM
I've been a big supporter of AMD for some years. Seems time to try Intel. Like the 1mg L2 cache on the (e) and 90nm chip, the dual channel memory, hyperthreading. blah blah
Any feedback is apprecited. There's so much info out there I'm not sure where to look or start.
Thanks..
whats the (e)?
in P4 setups i know that ppl would want better ram, PC4000 or so b/c they need ram that can handle the faster bus speeds that they want
The 'e' refers to the L2 cache level being 1meg. Step down from the Extreme version which has 2meg.
Not sure what to do between AMD and Intel.
If you're referring to the Prescott, I'd avoid it, as your system will run extremely hot.
any feedback. Any recommendations for mb/RAM/CPU. Don't don't any gaming. Mostly internet and graphics programs. Looking for the best value on good equipment.
I dunno about the Intel P4 EE. If you're going to spend that kinda money on a CPU, go for A64 instead, and save some money.
I love my Abit IS7-E, but if you want a cheap, no-frills board that's stable as hell, MSI's 865P Neo is a great board...if you can find it. It's pretty bare as features go, but it does have 6 PCI slots.
I've used my PC3200 Kingston ValueRAM in both boards without a problem.
For the CPU, definitely an 800MHz FSB. You'd probably get a good deal on a 2.4C-2.8C chip, overclocking or not.
