Which Manuf. are Proprietary (HP mainly)?
Rustynuts
Just wondering as my sister asked about HP computers and whether the stuff inside is "open-sourced" or are they proprietary? I don't follow these trends as I build my own PC's from scratch. I just remember the bad old days when the likes of Compaq, etc., made you buy almost all upgrades directly from them as nothing standard would fit, or work with the bios, etc.
most new pcs you can throw anything you want in them, stock or aftermarket
A lot of times the big manufacturers will use proprietary motherboard and maybe power supply designs in order to save money. The motherboards do, however, take all the standard components(processor, ram, expansion cards, drives). So it is proprietary in the sense that the motherboard was made specifically for that computer maker, but it still follows standards so that you can use third party upgrades with it.
