Which m.2 with which machine?
EricFX1984
Ok... so I have a few m.2 and a few machines. Trying to figure out WHERE I should put them
-Inland 2TB 3d NAND m.2 2280 PCIe NVMe 3.0x4
-ADATA XPG Gammix s70 Blade 1TB 4.0x4
-Silicon Power UD90 1tb gen 4.0x4
The first machine is:
Ryzen 5 7600x3d
Asus ROG Strix b650-a gaming WiFi
32GB DDR5 6000
rx 9060 XT 16GB
NOTE: this is my PC
2nd PC:
Ryzen 5 5500
(unknown motherboard)
2x16GB ddr4 3200
Intel Arc b580
NOTE: this is my son's future gaming PC
3rd PC:
Intel i5 10400
Asus Prime z490-a
2x16GB DDR4 3200
at least RTX 3060 12GB(maybe Arc b580 or a something else)
NOTE: This will be a budget gamer PC that my son and I sell
This guy is pci-e 3.0 max. If 1TB is enough for everyone, I'd put the inland here. If one of the others needs 2Tb though, then that might be more important.
My son says that he would really like to have the 2 terabyte drive... But I also feel like if I pair that with the machine that I'm selling I'm likely to get better profit
Does your son need 2TB of storage now or with in say the next 6 months or a year? if not, then put it into the one for sale.
UD90 in the 3rd PC for sale. I don't trust Silicon Power NVME, I had a P34A80 fail with very minimal usage.
Your choice on the other two. For real world usage there isn't much difference between PCIe 3.0 and PCIe 4.0 IMHO.
Ryzen 5 7600x3d
32GB DDR5 6000
rx 9060 XT 16GB
NOTE: this is my PC
2nd PC:
Ryzen 5 5500
2x16GB ddr4 3200
Intel Arc b580
3rd PC:
Intel i5 10400
Asus Prime z490-a
2x16GB DDR4 3200
G4 1TB ADATA in yours if it can support G4
2TB Inland in your kid's PC if it's G4
1TB SP in the 3rd. I never used SP.
I'm sure you could always update your 2 PCs in the future.
