I just bought the v1000b Plus 2 and now I need a PSU lol any suggestions?
I have a v1000b (couldn't possibly be happier with it!) and will pick up a corsair 750 soon (hopefully). I'm sure either the 1000 or 1200 would serve you perfectly!I'm using the corsair 750tx myself over here and it sits perfectly at the bottomyou can get a 1000watt psu if you like but you have to buy an extended bracket and it will protrude on the back of the case
