Which LCD should i get
Ok, spent 2-3 days researching on them all and yes iv read potential problems and other mics
I need a 20-22inch widescreen monitor for under $300 Canadian :p
Iv narrowed it down to these 4
E228WFP 22'' Widescreen Flat Panel LCD Monitor from Dell
http://accessories.us.dell.com/sna/productdetail.aspx?c=ca&l=en&s=dhs&cs=CADHS1&sku=320-5205
E207WFP 20'' Widescreen Flat Panel LCD Monitor from Dell
http://accessories.us.dell.com/sna/productdetail.aspx?c=ca&l=en&s=dhs&cs=CADHS1&sku=320-5123
LG 20.1" Widescreen LCD Monitor (L204WT) 8bit / 800 birghtness / tn-film
http://www.futureshop.ca/catalog/pr...665000FS10075693&catid=22335&logon=&langid=EN
Viewsonic VX2025WM 20.1
http://www.canadacomputers.com/index.php?do=ShowProduct&cmd=pd&pid=009557&cid=MT.258
Ok so there all 20.1 inch WS except the 22Dell which is same thing, except for the dot pitch being .284.
Which one should i get. Im leaning towards the Viewsonic but becasue it dosent have HDCP im skeptical. I dont know if i really need it or not. I do watch movies and play games, but im not buying a 360/ps3/blu-ray/hdvd
They are all $299.99 canadian
My thoughts are Viewsonic withotu HDCP and then the LG panel with HDCP
i cant find any info on the 22inch dell as it is very new, but any info on its panel would be nice. Its probaly a tn-fiml though
any help guys?
im about to head out right now to see how the view sonic and the lg look in person before i make my decision
