I am looking for a college laptop, right around 5 lbs with a 14.1 SXGA+ screen, at least x300 and under $2000. I thought that I had narrowed it down, but I have reached a bit of an impass. I have four laptops that I have found to fit the bill, and here they are:
IBM T43 2686DGU $1690.05 (IBM shareholder discount from techbargains)
1.86 Pentium M (750)
1gb DD2 4200 (2 DIMMS)
60gb 7200rpm
ati mobility x300
4x DVD burner
fingerprint reader
expresscard slot
IBM T42 $1649 (closeout sale deal)
1.8 (745)
1gb DDR 2700 (2 DIMMS)
60gb 7200rpm
ati mobility 9600
cdrw/dvd combo
Dell Latitiude D610 $1856 (with discounts)
1.86 (750)
512 ddr2 (1 DIMM)
60gb 5400rpm
x300
8x dvd burner
3year accidental damage protection
HP 6230 $1599
1.86 (750)
1gb ddr (2 DIMMs)
60gb 5400rpm
cdrw/dvd combo
x300
Now I can add damage protection to the IBM T43, however that will push it far up (~250 more). The reason I listed the T42 was because of the slightly better GPU, however it is behind as far as age considerations go. Even without the protection on the T43 I am leaning towards it as I am very protective of my equipment, and a spillproof keyboard seems to take away some of my fears. Also, there is the ExpressCard slot, which although meaning nothing now certainly adds quite a bit of upgrade possibility for the future. I don't care about DVD burning, although the 7200rpm drives are attractive. I have seen a couple reviews commenting on the mediocre quality of IBM's screen, which would be my only concern with it.
So any comments?
60gb 7200rpm
ati mobility x300
4x DVD burner
fingerprint reader
expresscard slot
1.8 (745)
60gb 7200rpm
ati mobility 9600
cdrw/dvd combo
1.86 (750)
512 ddr2 (1 DIMM)
60gb 5400rpm
x300
8x dvd burner
HP 6230 $1599
1.86 (750)
1gb ddr (2 DIMMs)
60gb 5400rpm
cdrw/dvd combo
x300
So any comments?
