Which laptop is best for Regular use?
Ladic
Mostly a working laptop.
Doing presentations, surfing the net, checking email, etc.
I'm deciding more for this HP:
http://slickdeals.net/?sduid=167302...p?skuId=8534188&type=product&id=1186008220258
But what about this Sony Vaio? its moer expensive, has more CPU speed, but the hard drive is smaller and the HD speed is also less
http://slickdeals.net/?sduid=167302...p?skuId=8525731&type=product&id=1186007524936
What is more noticeable for performance?
A slower HD (4200rpm vs 5400rpm) or slower cpu? (c2d mobile 1.5ghz vs 2ghz??)
what would be the better buy?
Personally, if I was to get a laptop strictly for work, I'd get those basic ones that goes on sale for like $400 because it's more than capable to do the job. In fact, thinking of getting that one from Walmart for my mom for her basic office needs.
With that said, if you can find the spare $200, I'd go with the Sony simply because of the processor upgrade. Both will be more than enough to do your daily office work, these will last you quite a while before needing an upgrade. I would also go with the larger slower drive because you will most likely not notice the difference in access times for work.
Hope this helps.
