Crazy tech
- Apr 7, 2004
I can get ether an prolink fx5600 256meg golden sample or an ati procolor 9800se 128meg which is better?
True, but if you can get a 9800se that will flash to a pro... In any case, dont get the 5600, especially not a 256mb 5600. Its just a waste of 128mb ram.The Batman said:Nethier...both suck. Either get a 5900XT or a 9800 pro. The extra $30-50 will really be worth it.
Wow, you gotta have some skill to replace BGA modules. You can actually do it?Crazy tech said:both need repairs to the memmory chips which I'll replace which I can do with my rework station.
I applaud your skill. I tried it once on a TI4200, and it didnt work. I'm pretty damn good with an iron too.Crazy tech said:Yes but It takes me about an hour per chip because the legs are so small and if you rush it the heat fries them.
