Hey, I've been doing lots of research on the potential of the system I want to build. I have looked extensively at intel and only a little at AMD. I am aware that AMD builds better stocks than intel, but I believe I can accomplish a lot with a prescott overclocked. Basically, I am wondering about specifics like fsb/clock that I might be able to achieve with my water cooled system on an AMD system and wondering if it would be able to defeat my dream system. I will have money from loans come september and this is what I'm looking at:
Pentium System:
AMD System
Oh yeah, and I can't decide whether to get a 300gb SATA or the 74gb Raptor. . . (I'm thinking about noise to performance ratio)
What FSB can I achieve with an athlon. I know that I can change the multiplier with certain Athlons, but I don't know what I can max out on (regarding fsb with 1:1 memory). I would choose the prescot because the Northwood cap(30 or 12) would decrease my chance of oc'ing the fsb to my 1:1 275. I know that with good cooling, I can get the prescot to where I want it. Here's what I'm planning on for the cooling:
The case I can't decide on, I'm thinking about the Lian Li PC-V1200 (a little bigger than the V1000) which I will mod a window to the case (I like to take risks). I would install either 2 BIX 120 or 1 BIX2 (another [H] task). I would have the Whitewater cpu triple nozzle WB and the maze4 NB waterblock and the swiftech pelt (mcw50-t) and possibly a hd cooler. I'm having trouble deciding on the pump because I could be running 4 blocks. . . I'm thinking of the swiftech or DD. I don't know.
I need as much advice as possible or places to look. I'm having a harder time finding overclock benches of the AMD systems than the Intel and I'm very confident about what I want to do with the intel system, but I would love to max out the potential of an AMD system if it would be worth it. I can't wait for september. Oh yeah, I'm also going to outfit my case with ColdC's, a 22" Mitsubishi/NEC monitor, and hopefully a matrix orbital 222.
Sorry for the long post, but I really need input, especially on AMD specs/bench possibilities.
Pentium System:
- P4C800-E delux
- P4 3.0 @ 275fsb for an OC of 4.125ghz (FSB would result in 1100)
- Geil Ultra 4400 3-4-4-8
- Enermax 600W PS
- Asus x800pro
AMD System
- Abit or Asus for 754 chipset??
- Athlon64 (the 754 or 939?) 3000+, 3200+, or 3400+ ??
- Geil Ultra 4400 3-4-4-8 (?)
- Enermax 600w PS
- Asus x800 pro
