CyberJunk
- Nov 13, 2005
which is faster 2x4 gb dimms or 1 8gb dimm ?
running on a z68 motherboard.
dual channel is faster.. but if you can buy the 1x8gb now and another 1x8gb in the future (better investement in the long run)
^the 64bit barrier really limits the uses of 16gb ram to not much other than running a lot VM's and maybe one or two programs. 8GB is more than enough.
Don't sweat over this. Either way you go you'll likely not notice any difference in performance unless your running creativity software that heavily hits ram. And of course in synthetic benchmarks. I would also go for the 4x2 though for dual channel.
Running multiple VMs will feel pain from not having enough memory bandwidth allocated to system memory.
If you're running in single channel, VMs will start to become noticeably slower, even if running off of a SSD.
