Which is better?
XBOA2000
Here's two options I'm considering costing nearly the same price.
ASRock 939Dual-SATA2
http://www.newegg.com/Product/Produ...N82E16813157081
and
eVGA Geforce 7800GT 256-P2-N515-AX
http://www.newegg.com/Product/Produ...N82E16814130247
Total= 264 for vid card ($20 mail in rebate and $20 EVGACPL coupon code) and 68 for mobo.
$332
OR:
eVGA Geforce 7800GT 256-P2-N518 w/ eVGA 133-K8-NF41 combo deal
http://www.newegg.com/product/Produ...N82E16814130238
Total= $350-20 coupon is $330.
So it pretty much comes down to which mobo is better. The ASRock has a slot for the M2 socket expansion, and is known to overclock pretty high. The EVGA mobo is usually worth $130 bought alone and has SLI and stuff. I don't know which is better.
the dual has both an AGP port and a PCI-E port. I'd say if your getting a PCIe card when you buy the mobo, i'd go for the bottom offer as at a later date you can add another card and be set with an SLI setup, whereas the Asrock one, you'd have to get another mobo.
Just my thinking of these 2 options.
neo out
