Which is a better Upgrade?
Aztlan
hi, I am undecided on which to go with
my current system is an
P4 2.4C @ 3.2 ghz
1 gig of PC2700 Kingston Hyperx memory
WD 74 gig raptor HD
9800 PRo
Audigy 2 zs
Plextor 12X dvd burner
Asus P4P800 motherboard
so the question is, which is the better upgrade,
upgrading the memory to pc3200
http://www.newegg.com/app/ViewProductDesc.asp?description=20-145-450&depa=0
or pc3700 (is cheaper than the pc3200, should I bother with this memory?)
http://www.newegg.com/app/ViewProductDesc.asp?description=20-145-442&depa=0
or go with a video card upgrade like a geforce 6800 gt
thanks
memory. i wouldn't mess around with pc3700 memory because of the loose cas latency/timings.
From the looks of your overclock, you seem to be doing fine on the memory side of things. You should get the video card. :D
Note that going from PC2700 to PC3200 is only a 16% improvement...
If I were you, I'd get some PC4000 or faster, so you can run at 1:1. In my experience, CAS latency means very little on Intel platforms.
get the fastest memory you can afford ... since you have an Intel system ... don't worry about the latency ...
Well, I am leaning more toward the video card, since I think it will be the upgrade that will boost the performance of the games I play more than the ram upgrade dont you think
A new card will boost your gaming performance, you will be held back by your ram speed. You are limiting your system by using slower ram than is required by the 800mhz fsb P4s. If you are only using the system for gaming, a new card will be fine. If you are using the system for other tasks too, a 167mhz boost in ram speed will increase the speed of your system in every app.
I guess you could sell your gig of PC2700 for about $100 and use that for the PC4000...
Does your PC2700 overclock at all?
Yes, I use the system mostly for gaming, music, internet, and like all people word processing since I am a university student
the ram overclocks to 181mhz, DDr362 thats what memtest86+ says
the cpu is oc to 3.26 ghz
so I guess is video card, thanks for the replies :)
LOl, your thread at the power supply forum made me laugh alot
anyway, I have a good power supply already, is an Antec True blue 480 watts one ;)
O
I'm just on a mission from God to make sure everyone everywhere has a good PS :D
Go with the fastest ram you won't be sorry.
I'd wait on the v card till the prices drop.
well, I guess you and the rest are right, I will instead buy the ram and wait for the video card
and yep, I have seen you post the power supply message :p
YAY! THE RAM GUYS WIN! :D :D :D What kind are you getting?
most likely this one since you guys say that high latencies doesnt matter in an intel setup, hopefully I can increase my overclock with this new ram
good or bad choice?
by the way, thats the highes i can go on ram, well 300 usd will be top
not more, so thats why i am thinking on buying the ram linked
but I am trying to spend the least i can, so maybe I will most likely buy this one
X2, so it comes to 266USD plus shipping
http://www.newegg.com/app/ViewProductDesc.asp?description=20-145-420&depa=0
I got my Corsair PC4000pro for only $299 at Outpost.com. Its very good ram, and has cool light thingys! With shipping it may be $5 over your budget, but you can sell your pc2700 for over $100 on Ebay or the FS/FT.
hmmm, how is the service at outpost.com
never ordered from that site, so I am a little uneasy
I think I am going to order these ones,
http://shop4.outpost.com/product/3746036
how is the one you have working?
you like it?
oh yeah, cant sell the ram, since my sister will want it for her system, since she uses a program from her work that requires alot of ram
Man, the shipping was the fastest ever. I ordered on Friday, and got DHL overnight (only like $6). The next morning I was woken by the sound of my doorbell. I recieved the ram at 11AM! Ram was packaged very well, and worked perfectly.
Thats the sticks I'm runnin, Real good stuff,my friggin cpu is holding me back :mad:
I've used Cousair for about 4 years, had a stick go bad in my other rig and called Newegg and they sent me a new one.
I've had great experiances with them.
