EgyptBoy20 said:nano. color screen and photo support, but it's very prone to scratches.
Yeah, I agree. I'd rather have 60GB than small size.NulloModo said:Both are ripoffs compared to the original. Come on now, the original is still tiny, and you get a ton more space for the money, go for it.
Xephian said:Yeah, I agree. I'd rather have 60GB than small size.
cair0 said:going from apples specs online, the iPod nano is 350% smaller in volume and 366% lighter than the iPod 60GB... not exactly insignificant
DanK said:I'd get an iPod mini. Twice the capacity for the same price, longer battery life (if you make sure you get a 2nd-generation mini), and no worries about scratching the case. What does the nano get you? Photo support? The screen is the size of a postage stamp. Color screen? It's going to be in your pocket, why does that matter?
I3roknI3ottle said:they have a 4GB nano for 250.
Cowcaster88 said:By the way what are you a PC or Mac user, with the iPod need? The iPod is easy enough for any untech savy person to figure out.
diablo111 said:My wife will be using it at work (sit down job)...maily to listen to music without the hassle of changing cd's, or having to mess around with it.
Do you have to use itunes with the shuffle or nano? That would be a huge minus...
Tengis said:I personally have an ipod mini... I got it for free or I would have ended up getting a non-apple player. Seems like you get more for your money with the majority of the other players on the market... you just dont have that "status symbol" hanging out of your pocket so girls will give you reach arounds.
peterhoang2002 said:You know that hard drives will break if they experience a lot of shock right?
DanK said:
c0ex said:I would go with the ipod mini b/c the nano is so small that you could probally accidently crush it.
Firebat said:The nano can overclock pretty good. But you may need some additional cooling for it.
Who's going to use 60gigs anyways? Even 20gigs? I smell a pirate.
danielj315 said:I hate the suffle!
Yay 1000 songs, Yet you can never choose
Yes yes playlists and so on but really,
"Hmm im happy i think il listen to, What the shuffle decides!"
DanK said:nobody has mentioned the inherent problem with flash players: flash memory has a finite number of erase-write cycles. Given two otherwise equal mp3 players, one HD-based and the other flash-based (with equally good care given to both), the flash-based player will be a paperweight long before the HD-based player has a hiccup if you change the music that's on it regularly. Yes, I realize that the number of cycles is greater than 1,000,000 these days, but that's still a limit that hard disks don't have.
