Rishy said:CAN YOU GUYS NOT RESPOND SO FAST !!!![]()
i hadnt even posted up the poll yet![]()
Fire away !
WhyYouLoveMe said:lol - That's funny.
Since "cost isn't a factor" I voted Ninja plus a wicked awesome 120mm fan. In the real world I'd vote for the Freezer.
quadnad said:Buying from Jab-Tech is significantly cheaper for the Ninja than most places...pity their regular "Ninja with your choice of five fans" thing has sold out
The Ninja is only ~$10 more than the freezer, and for the performance I think you're way better off w/the Ninja.
quadnad said:sry bout that, i used the price off of newegg.
the ninja is just far better at scaling in terms of cfm/dba, but still beats it in the high performance range. i suppose it's still all about how much you wanna spend.
Rishy said:thats for the effort and input guys..
keep em coming...i got about 18 hours before i pick one of em up![]()
Rishy said:hmmmmmmmmmmm....that thought didnt strike me![]()
Rishy said:hmmmm...so theres no outright winner then....
WhyYouLoveMe said:Well the point of having a window is to show off your machine!![]()
Looks are in the eye of the beholder so no one can tell you that it's ugly or stupid looking. It's all personal preference.
I think performance-wise the Ninja + Papst is the tops for air cooling.
Price/performance has to go to the AC64.
if u can take about 20 minutes u can just take the fan apart on the 9500 and clip the leds.Rishy said:can the fan on the 9500 be changed to a non LED or at least different colored one ?
Haste266 said:if u can take about 20 minutes u can just take the fan apart on the 9500 and clip the leds.
i did that on mine because i hate blue.
Rishy said:i know im just being a paranoid android...but theres a fear of it breaking off and crashing into my 7800GT....course..that would give me reason to go 7900...but still
also, new case will be a Stacker 830W...everything else in my sig is the same.
i have a btx case_Korruption_ said:I think you've got it installed backwards. It is blowing the wrong way.
no, I think he is saying that the HS fan is blowing toward the front of your case while the 2 case fans are blowing toards the back. The fan of the 9500 blows air across the HS.rox1co said:i have a btx case
i just fixed it, kinda waste of time - i'll have to do do it again when i get my arctic silverIDversusEGO said:no, I think he is saying that the HS fan is blowing toward the front of your case while the 2 case fans are blowing toards the back. The fan of the 9500 blows air across the HS.
