Currently I have a Zalman 7700Cu. I just bought an X2 3800+ that will do 2.8-2.9Ghz on 1.5V. The zalman kept my FX-55 (1.5V) running at 39 C idle and 49 C at load. Will it be the same for the X2 3800+? Should I be looking at getting a Scythe Ninja with a 120mm fan (maybe 2)? I have a Lian Li PC-60 Plus (took out the squirrel cage fan) and a DFI LanParty Ultra. I heard the Scythe is a pain, will it be a bigger pain when I have to remove the zalman backplate and put on the scythe one?
Thanks.
Thanks.
