toymachineman19
Guest
- Dec 26, 2004
Ok, I am getting this mobo: http://www.newegg.com/app/ViewProductDesc.asp?description=35-109-114&depa=0
with an A64 3500+ when I build my computer. I am stuck between the thermalright SLK-948U Heatsink http://www.newegg.com/app/ViewProductDesc.asp?description=35-109-114&depa=0
and the Thermalright XP-90 http://www.newegg.com/app/ViewProductDesc.asp?description=35-109-119&depa=1
Both fit a 92mm fan, and I hear both are good. I would use the XP-120, but I want to use DIMM #1 (which I can't with this mobo and the XP-120), so I would like to know which is better, and they are both about the same price as well.
