Funky_Junk
- Oct 1, 2005
Im picking out a heatsink for my soon to be heavily overclocked X2 3800+ and I need you to help me pick between these two, or if you have another suggestion let me know. First of this is my case and mobo: I should warn you that I dont have the best aiflow.
http://www.xoxide.com/kiktb.html
http://www.newegg.com/Product/Product.asp?Item=N82E16813136152
Heres the two heatsink choices:
http://www.xoxide.com/zalman-cnps9500-led-cooler.html
http://www.xoxide.com/thermalright-xp-90c-cpu-cooler.html with http://www.sidewindercomputers.com/pa92mesp.html
The only reason im reluctant to go with the zalman is because i heard that is sorta loud. And with the Thermalright I can always just put a low speed fan if I think its too loud. Thanks for the input.
