Which HDMI cable?
  • Thread starter Deleted member 108676
  • Start date
D
Guest
Theres oodles and oodles of HDMI cables and I was wondering which one would be the best for me? My TV supports 1080i/720p/480i/480p.
I searched and couldn't really find what I thought I was looking for so help and the lack of flaming will be appreciated.
Thanks.
Whatever is cheap. Over short distances, quality isn't really relevant. Provided it's built to spec it'll work just fine. I'd get one from Datapro as they are cheap and good, however you needn't order one, buying one in a local store will work fine. Just don't waste your money on the expensive ones, they make not a bit of difference.
Yeah, unfortunately most of the major local retailers (BB, CC, etc) carry Monster exclusively and they charge you insane amounts of money. If you *really* want monster, you can get them 1/4 of the price on ebay or you can get almost any other type of cable and it'll work just as good if not better.
Thankfully im getting a 6ft Monster HDMI-DVI cable for $20 unopened locally which is worth it I think.
