Which GT's with H50?
StillFunkyB
Which GT's work best with the H50 Push/Pull?
What about intake/exhaust for the rest of the case? I don't mind a little noise, but the CM fans I have right now are too loud. It didn't matter for noise before as I was running a window unit for AC, but I am getting central air now so I want something quieter.
Thanks.
The 1850's are quiet with a tiny bit and barely noticeable hum sound if you're up close. Either way they're probably quieter than anything CM puts out. Another thing you could consider, which is what I did, would be purchasing two PWM fans. I used two Gelid PWM LED Wing's, which are a tiny bit louder than the GT AP-1850's (still very quiet) at full speed, but they did shave off 1-2 degrees under full load not to mention they generally won't be running at full speed anyway. I got mine from Performance PC's, and while they do also have them on Newegg, they're priced a bit higher. Here's the link...
Blue - http://www.newegg.com/Product/Produ...426024&cm_re=gelid_led-_-35-426-024-_-Product
Green - http://www.newegg.com/Product/Produ...426025&cm_re=gelid_led-_-35-426-025-_-Product
If you have a fan controller get the GT1850 and turn it down to 1600rpm for total silence. It also depends on your case fans though, if one of those is louder than the GT1850, then just leave'em at 1850rpm. For case fans with no obstructions (filters), get a Scythe S-Flex.
