Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I am getting a Thermalright SLK-948U heatsink for overclocking an AMD system and I want a high cfm fan that will do a very good job but I dont think I want the Vantec Tornado that sounds like a vaacum cleaner. What are some you guys would recommend?
I am wondering the same thing, I have the same heatsink, but I want a larger, more effecient fan. Any 92mm fans that push a lot of CFMs? I'll put an 80mm if I really have to, but I'd like to have the larger fan, sound is NOT a concern.
A 56cfm 92mm Panaflo would do a very nice job. I was using one on my Swiftech MCX4000 till I got a Zalman 7000alcu, it was great. <plug> In fact, I have one for sale, $6 shipped. PM me! </plug>
just settle for a CFM vs. noise ratio that you can tolerate. Or buy a Tornado and hook it up through a fan controller, and set it at the level you can tolerate.
