Joni Nitro
- Mar 20, 2005
I am putting to MCR320s in series on a single loop with a MCP655. They are going in a NZXT Switch. One is installed in the front of the case and the other on the top I am currently cooling a i7 930@4ghz and a single 7850. I may add a second 7850 later. I could run possibly 4 options.
1. 1 rad with 3 med YL in push in the front of the case and 3 med YL in pull at the top.
2. Rad in same location but both in push/pull
3. Same as option 1, but with Ultra Kaze 3000rpm fans at about 1000rpms for daily use.
4. Med YL push/pull on one rad and Ultra Kaze @1000k in push or pull on the other.
All fans will be controlled with fan controller and I am looking for best cooling to noise ratio.
I already have 6 brand new med YL and I am not going to drop the cash for GTs or anything else, unless it is for 6 more med YL If you think I should go push/pull, then why? If I am not going to reduce cooling by at least 5c or reduce noise by running them all slower it wont be worth it.
I have tried to look at SkinneLabs to see if I could come up with some similar scenarios. If you have a link to some test or benchmarks please link them.
Thanks.
Thanks.
