Which EK SLI Bridge To Use ?
Tinmann
I'm in the process of building a custom loop I'd like to ust the EK FC Bridge Dual Parallel - 3-Slot - SLI Connection
http://www.frozencpu.com/products/1...ction_EK-FC_Bridge_DUAL_Parallel_3_-Slot.html
I am using the Asus p8Z68-V Pro motherboard. My GPU's sit in the slots pictured.
The question is which bridge do I need, the dual or the triple ?
I don't know if it's been done but I'd like to mount Yate Loon 140mm fan + Bitspower Low Profile 140mm To 120mm Fan Adapter
http://www.frozencpu.com/products/9...an_Adapter_-_Black_BP-FA140120-BK.html?tl=g47
Then mount a 120mm rad to the adapter and another 120mm fan to the Rad in a push/ pull
configuration in the bottom compartment of the Corsair 800d.
I'm using a TFC X-Changer 360 inside the top of the case and I'm hanging a 140mm Black Ice GTX inside the back of the case.
Any advice with be greatly appreciated.
I just put these together: http://hardforum.com/showthread.php?t=1682197
I used the Bitspower adapters and acrylic tubing. It was simple and the cost was about 20 dollars total.
You would need the two slot acrylic tubes.:D
Or, measure the distance (in mm) from the back of one GPU to the back of the other GPU and add about 18mm, that will give you the length of acrylic tubes to order.....they come in 3 packs in 5 mm increments.
