I just bought a 500gb drive that will serve exclusively as a Sonar 7 Audio drive (the audio folder will be here, and nothing else).
Here is my CURRENT drive set-up :
C: = Bootup Drive, contains all programs (including Sonar itself)
D: = Documents Drive, contains project files, bundles, etc.
E: = Audio Drive (NEW!)
Until now, the Audio Folder was on the Documents drive... but I'm quickly running out of room there (15% left). Hence the new drive. I now need two masters and a slave. Or two slaves and a master. Whatever. =) But I'd like to know what your recommended ideal Master/Slave config would be.
Should C (programs) and E (wave folder) each be a master? Should E be the slave of C? Etc.
Thanks!
PS: They're all SATA.
Thanks!
