Jan 16, 2007 #1 R ryansebiz Limp Gawd Joined Aug 5, 2005 Messages 430 I'm putting together my first C2D build and trying to figure out the best way to mount the Tuniq Tower in my P180B. If I want hot air to blow out of the back of my case should I mount the Tuniq like this: Is this the best way to mount the Tuniq?
Jan 23, 2007 #3 V videomasterz Gawd Joined Nov 9, 2006 Messages 834 which ever side the fan wire is on.. is the way air blows... is if fan wires is on the left side of the fan it blows from the left...
Jan 23, 2007 #4 D deaNhaycH n00b Joined Oct 22, 2006 Messages 47 thats correct, im looking at mine now to compare, so its definately right. Mine exhausts out the back.
May 18, 2007 #5 B Blueduck577 Weaksauce Joined May 11, 2007 Messages 110 Piggybacking on this thread... Why are there two connectors that sprout from the Tuniq...I know one of them (red one) connects to CPU_FAN on the mobo, what does the other one (white) connect to?
May 18, 2007 #6 B Blueduck577 Weaksauce Joined May 11, 2007 Messages 110 Wow, didn't know this thing came with the rheostat. Nevermind.
May 18, 2007 #7 T texmaster [H]ard|Gawd Joined Apr 30, 2007 Messages 1,271 Here is my layout if it helps http://i11.photobucket.com/albums/a191/texmaster/Picture008.jpg
May 19, 2007 #8 V videomasterz Gawd Joined Nov 9, 2006 Messages 834 texmaster said: Here is my layout if it helps http://i11.photobucket.com/albums/a191/texmaster/Picture008.jpg Click to expand... mine is the oposite way... did you turn your fan around so it will blow out the rear? if you didnt seems like the fan is blowing IN your case...
May 30, 2007 #9 R ric27 n00b Joined May 18, 2007 Messages 1 texmaster said: Here is my layout if it helps http://i11.photobucket.com/albums/a191/texmaster/Picture008.jpg Click to expand... Nice looking case
