I have moved to i7. 920, eVGA Classified and eVGA GTX285sc on the way. Also ordered the cheapest ram newegg had to use temporarely and as back-up once I get better ram. Other parts will come outta my P45 build.
My knowledge on overclocking is limited, but I would like to get more into it. Everything will be water cooled on a pretty massive level once I get around to completing my scratch build case.
I like the Corsair Dominator DDR3 2000 7-8-7-20. But it is over $500. The cas 8 version is more acceptable to me at $320ish. Then there's the Gskill and OCZ (DDR3 2000 7-8-7-20) which I guess are the same chips as the Corsair but at a more agree-able $400ish. And probably other options I am unaware of.
How much difference will the cas 7 have over the cas 8? How are the Gskill Perfect storm and the OCZ Blade compared to the Dominator GT?
