Isn't H7 overkill my current specs?
How about Cryorig M9i? Isn't much more cheaper and fit my current specs?I wasn't aware that was a requirement.
I was going off the fact that you aren't overclocking and the H7 is the cheaper of the 3 and probably cools just as well as the H5.
So the H5 might be quieter, just make sure it fits in your case. It might be to tall.
