which CRT?
I have the G90FB at the moment.
The things you'll like and not like about this monitor are:
Good:
Refresh Rates, this thing can operate at very high resolutions while maintaining a high refresh rate round' like 85-100.
Looks: It's black and has flat screen/anti glare feature. Always a plus if you're in a heavy lit room.
Color: Brilliant display of colors, don't know the exact number but everything I've seen projected thus far is awesome.
Bad:
It weighs alot (duh CRT) but this is exceptionally high for a 18' monitor.
Depth: This thing is very long, you'll need about at least a foot and a quarter to fit on your desk.
Artifacts: In Hl2/BF2 i've noticed artifacts in the AA/AF, like you'll see very little dots , it's not my GFX bc I used an LCD and I couldn't see them on there. Also I plugged this into my other computer and it does the exact same thing. (played using 1024x768 @ 85H 32bit)
Positioning: It's a royal pain in the ass to position everything on the screen. Till this day I can't get everything properly alligned, there's too many options.
Overall:
If you have the room, can configure well, get this monitor.
I Think I know the little dots you are talking about.Its not the monitor that does this...thats the way its supposed to look like.Ive played hl2/bf2 on many different monitors/systems and the same part of certain maps have that detail you are talking about.
Thank you for the review of that Viewsonic its probably whatim going to get
