blacklotus
- Apr 26, 2006
Guys,
Im building a system from a scratch and need some advice on which CPU to get. I leaning into something of a bang for the buck performance. I have a limited budget and will spend most of my $$ for the 7900GTX so i need a good performing CPU that would not bottleneck my GPU. Im thinking of getting the X2 3800+ or the X2 4200+. Is there a big difference? Im not overclocking by the way. Thanks
