decided I'm going to switch to an Intel based gaming rig. Current system is FX-6300 / Gigabyte 990FXA-UD3 and managed to OC the FX to 4.6GB stable using air cooling. What hardware would be either a lateral or upward move from the current AMD based hardware I'm running? The graphics card is a GTX 970 and I plan to upgrade to a GTX 1070 or 1080 in the near future ...
My budget is $300 for both cpu and mobo. Any Intel cpu/mobo recommendations are appreciated. Thanks
