which cpu fan??
depends what your goal is...
you looking for max OC, without caring about the noise? If thats the case, I would go with the aerocool...
If you looking for a real good overclock, that is real quiet compared to the aerocool, go with the s-flex... I personally have 4 s-flexes in my system, and I love them
Get the Zalman 9700. It is huge and awesome. My Q6600 @ 3.01 GHZ idle 30-36 100% load 48 max.
Just make sure to read the directions carefully, and be prepared to unknowingly get cut from the heat fins.
Are those the only two you're considering? I really like my Geminii, and they frequently have huge rebates (I know for a while it was $0.01 AR).
Get a Yate Loon from xoxide.com for 3.99 (They have 3 versions L, M, H), I just ordered 4 of the M's myself.
And the Zalman 9700 is a HS/F not a fan by itself, He's wanting a fan by itself.
