Hello,
I’m in the market for a great CPU cooler for my new setup i7 920 CPU & P6T Deluxe v2 MOBO.
I will be OC this system to a 4Ghz (at least I will try) so the cooler must be good. The only requirement I have is for it not to be over 160.5 mm in height as my Cosmos S case has a 200mm fan on the side that will restrict anything higher. The 160.5mm is a height of a True 120 so I drought there will be problems as most of them I believe don’t exceed this number. If however there is something out there that is truly great but is over 160.5mm please name it I might end up doing some moding to the fan to accommodate & the cooler need to be socket 1366 competable (duhhhh)
Anything with in $100 range works for me. From my 30 min researching these are the 3 that I am looking at:
Thermalright IFX-14
Prolimatech Megahalems
Ultra-120 Extreme RT Rev.C
Thanks
Thermalright IFX-14
Thanks
