BBowermaster
- Sep 14, 2004
So I sent back the Fortron I bought as the fan had no throttling. It was an 80mm fan on 24/7 full blast. I figured it was worth the 15% restocking and shipping for years of silence.
I've decided on buying one of the Corsairs, due to the reviews and 5 year warranty. The question is, which one to get.
I will be powering the following system :
Core 2 Duo E6400
MSI P965 Neo-F
512mb or 1gb DDR2 PC5300
Geforce 7600 GT
2x 120gb Hard drives
Soundblaster Audigy 2
2 optical drives
1 120mm case fan
1 80mm case fan
So the question is, will I be good with the 520w, or will the 620w be a good investment for future upgrades? Consider that I don't upgrade very often; I'm upgrading from the system in my signature, which I built back in 2003. I just don't want to invest in the 620w, and then by the time I upgrade again, processors and video cards will require 1000w power supplies.
Also, if anyone knows where to get either one cheap, let me know. I'm currently looking at ZipZoomFly, as Buy.com appears to be sold out for an undetermined time.
Core 2 Duo E6400
MSI P965 Neo-F
Geforce 7600 GT
2 optical drives
1 120mm case fan
1 80mm case fan
