Canadian 2.5RS
- Sep 12, 2006
Can we get a list together of cases that will fit a triple rad internally?
The only one I know of is the TJ07
WORLDS ONLY HYPER MODULAR COMPUTER CASE
The new HYPER MODULAR design puts a new spin on an old staple! Options are seemingly endless.
NOW for water cooling enthusiasts choose your fan hole spacing for your specific radiators!(Thermochill or Swiftech/Black Ice)
In the front hold a Thermochill PA 120.3, Swiftech MCR320, or Black ICE Triple radiator while on the back choose Thermochill PA 120.2 or Swiftech MCR220/Black ICE Double radiator spacing.
Screw MM UFO cases...they are clunky and unbelievably heavy. If you want a case that involves minimal modding to fit an internal LC system, get TT Armor/Kandalf, CM Stacker T01/810, Silverstone T07, or one of the premodded cases from performance-pcs/frozencpu. If you do not care if its internal or not, get a Gigabyte Aurora, Antec P180, Antec 900, or any other case with pre drilled holes.
Yeah Mountain Mod cases are AWESOME. I used to own one and after looking at that case that was linked I am probably gonna get a new one. That one is hella sweet with the powder coat on it.Guess you never owned one............, they are lighter than any steel case out there and that includes the Antec P180 and Cooler Master Stacker (I've owned both), so you might want to learn a little about what you're talking about before you run your mouth off. Granted they are (Mountain Mods) a big cube, but a lot of folks like the extra room for running multi loops without having to cut up their case and have radiator hanging off it all over the place. So screw all those that you mentioned...............
http://www.antec.com/us/productDetails.php?ProdID=81800
Weight (net) 31 lbs
http://www.coolermaster.com/products/product.php?act=detail&tbcate=17&id=13
Weight 10 kg
http://www.mountainmods.com/u2ufo-black-wrinkle-powder-coat-3-big-window-p-432.html
Empty Weight - 15 lbs.
Weight (net) 31 lbs
Weight 10 kg
