Which case would you keep?
acee
Ok so I have 2 cases...
Antec 900
and
Thermaltake Armor Jr. Black edition
which case would you keep for temporary? because I'm going to get a Lian li or Silverstone case after one of these sells but not sure when will be the day. After I get a Lian li or Silverstone I'll sell the temporary case.
I would keep the Antec since I hate Thermaltake cases with a passion. If you're getting a new case soon it doesn't really matter either way, but I think the Antec would be a better choice.
Antec over the Armor ONLY because the Armor is a jr and not a full sized Armor
My favorite ten
1, CM Cosmos (I can watch TV in the reflection off the door which is also interchangeable)
2. TT Armor (Its a STEEL ROCK....and I mean that in a good way)
3. CM Stacker 830 (if you are going to be a bear, be a grizzly!)
4. GB Aurora (good water cooling, plenty of room, neat all around and nice door)
5. TT Shark (mean front)
6. TT Mozart (for the wow factor....freaking thing is hugemongous)
7. Antec 900 (low priced but nice profile and strong body)
8. Antec P182 GM (yummy)
9. YY-0221 Cube Case (first case I would consider if modding was on my mind)
10. CM Centurion (good cheap case)
alrite thanks guy.. then i'll sell the thermaltake case first then get a new case then eventually the antec 900 :D
