Which Case would be best?
Antimatter
I'm looking to mod a shuttle or some sort of enclosure, i want to make a NAS that is as small as possible yet powerful.
Anyway here's the 5 in 3 drive cage Cage
Now I have spent next to forever searching for a case to put these bad boys in, and I've so far found two possibility, one is
Shuttle case
-or-
Drive Enclosure
Now I'm wondering which one would be the best, someone already took the shuttle case and did a mod to it Udat
Now ideally I want to do something similar to this, but one problem is the drive cage is a bit larger so it might not even fit into the shuttle case, so I'm not sure what to do, if i could just mod the shuttle case to make the power supply stick out a bit more, or move the power supply somewhere else but I'm not sure where/how.
So which would ultimately be the best and easiest case to mod, the shuttle or one of those drive enclosure, I'm thinking of the 4-5 bay enclosure, so i can have some room on the bottle of the case for a power supply and the motherboard....
Any recommendation?
