which case should I use?
EricFX1984
I am getting ready to put my water rig back together
Phenom II 965 @ 4.0GHz water cooled
Asus m4a88td-evo usb 3.0
EVGA gtx260 Super clocked
4GB Corsair Dominator DDR3 1600
74GB raptor x 2 raid 0
1.5TB Seagate 7200.11
Cooler Master Silent Pro 700 watt modular
water stuff:
Swiftech 120.3 (I have 2 of these) might run both might not, they will likely be top mounted
Yate loon 120mm high speeds
EK Supreme
I have this case... NZXT Gamma, window modded, figured I could mount the radi on the top
http://i759.photobucket.com/albums/xx239/ericfx1984/DSCF1767.jpg
http://i759.photobucket.com/albums/xx239/ericfx1984/DSCF1768.jpg
http://i759.photobucket.com/albums/xx239/ericfx1984/DSCF1765.jpg
or my home brew tech bench
http://i759.photobucket.com/albums/xx239/ericfx1984/DCAM0016.jpg
http://i759.photobucket.com/albums/xx239/ericfx1984/DSCF2019.jpg
http://i759.photobucket.com/albums/xx239/ericfx1984/DSCF2018.jpg
http://i759.photobucket.com/albums/xx239/ericfx1984/DSCF2016.jpg
you are going to mount a 120.3 rad on top where there is only 2 holes? this might actually work, you just wont have the benefit of the third fan. you think you could use the 120.3 as if it were a 120.2?
nope I would still have all three fans... If I just ran one radi I would space it out from the case, if I run 2 radi's I would put them on top but on the side
