Which Case is Better for my Build?
NYXX
I plan on building this type of System:
Intel Core 2 Quad Q9650
ASUS Rampage Formula
Mushkin 2x2GB 1066 DDR2 Memory 5-5-5-15 or Mushkin 2x2GB 1000 DDR2 5-5-5-12
Western Digital 750Gb Raid Edition 2
Western Digital 500GBx2
ATI RADEON 4870X2 2GB
ANTEC 850 WATT QUATTRO or Antec 850Watt Signature Series
DVD/CD WITH LIGHT SCRIBE AND DUAL LAYER
Which Case is best:
Antec 1200
http://www.antec.com/us/productDetails.php?ProdID=15120#
or
Thermaltake Armor+ VH6000BWS
http://www.thermaltakeusa.com/Product.aspx?S=1226&ID=1408#Tab0
i'd go for the 1200 for personal preference (looks),
but both cases have extreamely good airflow which is importnat cuz your build looks like its gona output a ton of heat.
so in the end, you should pick which one you like best =)
+1 for the 1200. im actually thinking of changing up my 900 for a 1200.
+3 for the Antec. I've never been a big fan of anything Thermaltake...
I think the Thermaltake fell out of the ugly tree and hit every branch on the way down, although it has the ability to hold 4 dual slot gpus if you're into that sort of thing.
I'd go with the Antec out of those two, but I recommend you also take a look at the Coolermaster Stacker and Cosmos series of cases.
