which case for my new system?
litehedded
evga 8800gts
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130038
e6600
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115003
corsair ddr800
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145034
asus commando
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131149
that's my new system^
which case do you recommend?
I want something with a removable mobo tray
I was thinking this lian li:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112116
what do you think?
I want a big cooler like the zalman 9700 or the tuniq tower. will they fit?
well what is your still gamer look, sleek&clean look, curves, or just anything suits you?
evga 8800gts
e6600
corsair ddr800
asus commando
what do you think?
something with a window and top notch build quality.
I don't want a case that looks like a UFO either
not much more than the lian li above
I like the looks of that case if it gives you an idea
would the larger coolers/video card fit in that case?
yes they should fit fine in that case but i havent done my homework so you might want to look around on here theres a thread here on the forums with cases that the tuniq tower fits in should give you a general idea on some good cases as well.. also check ebay for some cases i just picked up a tj07 for $100 shipped so im damn happy about that :)
ill also be looking around for some cases for you and post back here in a little while
ok i'm looking at a list now and going by memory so bare with me here.
first up the COOLER MASTER Mystique (they have black but i like silver and blue :p)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119119
second GIGABYTE 3D AURORA (also have black this is just first color i saw)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811233004
third Thermaltake Eclipse
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133006
foruth Thermaltake Tsunami
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133133
fifth Tuniq IC-SYMI-BK (my guess is a tuniq tower should fit in here since its same company though i cant vouche for how well built the chasis is)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811166019
sixth SILVERSTONE TEMJIN SST-TJ06B-W (cant vouche but looks sleek and well built)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811163035
seventh SILVERSTONE SST-TJ05B-X
http://www.newegg.com/Product/Product.aspx?Item=N82E16811163036
eighth AeroCool ZeroDegree-SV (cant vouche but looks sleek)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811196024
im comming to an end here but im sure theres plenty more im just doing a quick search on newegg
ninth Simga Luna Black (very nice well built structure sleek as well but the one con is the triangles on the side panel that hold the window in, but i know a hardware store should have the bolts to replace them)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811226005
for now thats all i have to say on cases ill leave the rest up to the other fellow [H] members
I think I'm pretty close to going with the lian li case
if the bigger coolers will fit in it I might be sold
yea lian-li's are damn nice and light weight but still being able to stand on them too. so just do a check here on the forums or on google to see if you can find anything on that case and look for posts to see if the tuniq fits i do know a thermal take big typhoon will
