Which Card to Choose?
T
Tokey
Guest
Hi Guys
Fairly certain this is the final thread im going to be doing in my quest for a new PC. Most of the components are all but decided I just need a little help with the graphics card if thats ok.
The Components so far are:
Asus P5N32-E Motherboard
Intel Core 2 Duo E6400 2.13
2GB Kingston DDR2 667Mhz
Western Digital 250GB SATA2 16MB Cache
Cooler Master Centurion 534
Antec True Power 2 550w
I need to choose between the following graphics cards (all Nvidia 7600GT)
256MB XFX 7600GT XT, PCI-E (x16), Mem 1500MHz, GPU 580MHz, 12 Pipes Dual DVI/HDTV
Manufacturer Link
256Mb XFX 7600GT,PCI-E (x16), XXX,Mem 1600 MHz,GPU 590 MHz, 12 Pipes
Manufacturer Link
256MB XFX 7600GT XXX, PCI-E (x16), Mem 1600 MHz, GPU 590 MHz, 12 Pipes, Dual DVI/HDTV SLi
Manufacturer Link
BFG GeForce 7600 GT OC 256MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail
Manufacturers Link
They are all pretty much the same price so any advice as to which one to choose would be much appreciated. Its also worth noting that there is a good possibility that i will want to hook this graphics card up to a HD LCD/Plasma TV.
-edit-
Just spotted this card which looks like its going to be the winner. Its only a couple of $ more.
256MB XFX 7600GT 'Fatal1ty' PCI-E(x16), Mem 1600MHz, GPU 650MHz, 12Pipes, Dual DVI/HDTV SLi Passive
Manufacturers link
