Edited: Which of the following cards is the best?
GIGABYTE GEFORCE 8800GT PCI-E 256MB GDDR3 256BIT DUAL DVI HDTV
ASUS GEFORCE 8800GT PCI-E 512MB DDR3 256BIT DUAL DVI HDTV (EN8800GT/G/HTDP/512M)
EVGA E-GEFORCE 8800GTS 500MHZ 320MB 1.6GHZ GDDR3 PCI-E Dual DVI-I HDTV HDCP DIRECTX10 Video Card
EVGA E-GEFORCE 8800GTS Ssc Crysis 112SP 576MHZ 640MB DDR3 PCI-E DVI-I HDTV DIRECTX10 Video Card
BFG GeForce 8800GT OC 512MB GDDR3 PCI-E Dual DVI-I HDCP HDTV Out DIRECTX10 Video Card
I know they're very similar, but they all differ in prices and I wanted to make sure I would be getting the best one. Also, do some brands perform better than others?
Thanks.
Thanks.
