- Dec 28, 2004
So I recently had some troubles with my EVGA 7900GT and had to RMA it.
Before I sent it out I bought a BFG 9600GTOC 512mb to put in my system thinking I would just keep the 7900GT to use in a second box, or as a spare.
Well EVGA sent me back a 8800GTS 320 as a replacement. As far as I can tell this is right on par with my 9600 in terms of performance.
So I've been doing a little testing this afternoon and found a couple interesting things.
The 9600 beats the 8800GTS in 3dmark 06 by about 200 points.
In the only game I've played on both systems in the last 24 hours (TF2) my recommended settings in the game are much higher with the 8800GTS and my framerate doesn't seem to dip as far in large firefights. I know I'm CPU limited in this game but the 8800 seemed a lot smoother.
I'm probably going to swap the 9600 back in here in a bit, and do some further testing.
Now if it was your system which card would you use as your main video card and why?
