Which C2D is best for FSB OC'ing?
djgizmo
I'm looking to buy some high end ram, and wanna push it to the max. Any recommendations for C2D that can OC the FSB to the max?
Thank you in advance!
They all seem to do pretty well, assuming you can cool them and the board doesn't have any problems.
You may have the lower the multiplier however.
I bought some OCZ Titanium VX2 PC8000 and a C2D E6420, hoping to reach FSB of 500 x7 for 3.5Ghz with the ram synced. I chose the 6420 because in the case I cant get a stable FSB of 500 I will have at least a 8x multiplier to play with wich I wouldn't with a 6320.
Yep, already got it covered. Going to invest in a Cool It Freezone.
Well the original 6400 were probably the best OCers since they had less cache... but 500 is going to be hard to get unless you are lucky anyway.
