Slartibartfast
- Sep 25, 2004
Hey all, real quick question: I'm probably going to order the Thermochill 92.1 radiator from here:
http://store.over-clock.com/ThermoChill.html
Down at the bottom they have barbs for it, both nickel and plastic. I remember reading somewhere that it can be bad to mix metals in a wc setup, so assuming copper blocks, I would be better off getting the plastic barbs, correct? Thanks
