- Oct 7, 2003
No AV software, and scan suspicious files/downloaded files with metascan-online. If the file passes the 40+ AV engines of MetaScan, its GTG. Unchecky to keep toolbars/PUPs from being installed.
Testing things in a lab is one thing and not indicative of actual real world performance I'd respond.
I do this. And also have Malwarebytes, SuperAntiSpyware, & Peerblock running in the background. And Noscript in the browser with a custom whitelist.
I find them each catching/blocking different things at times.
What do you do to protect yourself against zero-day exploits and malvertising attacks?
When Microsoft comes out and says PLEASE DON'T USE MSE, I think it's a hint not to use MSE.
If you want something free, Panda Cloud is excellent. Fortinet is quite good as well.
And yet all I use is MSE and every other product can't find a damned thing when used to scan the same machine MSE is and has been used on for years now, go figure. Either I'm the luckiest user alive or MSE is actually working as designed.
Anyways, is the MS firewall sufficient? I want to use Comodo, but alas not yet.
I hope this doesn't sound crappy, but: How so?Except setting rules for outbound connections is horrible
Use the tool I posted then compare to how Windows does it and you will see why I said that. What I posted uses the Windows firewall and is not a standalone firewall. It just makes setting rules much easier.
So it's very similar. See the comment on the video. That one at the URL you're hawking seems to be offered by more than one vendor.That video is not the firewall app I have, it looks like it might be the rogueware version of it though. Look at the download url, it is not the one I posted. All 3rd party firewalls have inbound and outbound control. A lot of progs/games phone home when you might not want them to. FRIEND!
Yeah, I'm not going to use it. Because what you're alleging to be difficult and confusing is neither.
ThatStupidArticle said:The Windows firewalls advanced interface is designed for system administrators, while other firewalls are designed for users.
Hate to break it to you but he's correct. A firewall that doesn't block inbound and outbound connections by default is totally useless.
Does not compute.Now I understand totally why this functionality is not enabled by default. I tried running a personal firewall at my mothers and wifes computers when they were still on windows. Let's just say they couldn't cope with it![]()
Going with eset nod32 and malwarebytes pro on win 10 although i have lost a bit of faith in malwarebytes as well given the above situation.
Has anyone else had a bad experience with malwarebytes? So far I have only seen this one comment.
For free antivirus Panda and Bitdefender are the best currently. Though the former comes with toolbar so be mindful what you click when installing and latter requires you to register a profile.
I used to use Comodo Firewall but it does not work for W10 yet. Currently I use Private Firewall as alternative, but jury is still out how good it is.
