Which ATI Cards Are " Crossfire Ready" ?
I think only the X800XT/PE / X1800XT/PE and the X850XT/PE / X1850XT/PE are Crossfire ready all you need is a Crossfire Master Card and the Crossfire Mobo.
as far as the x800 line up is concerned, i believe it involves the pro's, XL's, and XT's (add XT PE in there too)
the x1800, and x1600 are supposed to be crossfire enabled too
Every single X800, actually. Includes the GT, GTO, NP, Pro, XT, XTPE.
And of course the three X850 versions - Pro, XT, XTPE.
With the GT and GTO, you have to check the core. R423 core = X800 Mastercard, R480 core = X850 Mastercard.
And yes. The X1800s and X1600s are all Crossfire ready. Or will be... ;)
The Doc said:
Anyone have any idea?
all the X800 series and x1800 series are crossfire ready however in order to enable crossfire you need the master card and not every card is a master card..
All crossfire ready cards say so on the box. That is the easiest way to tell.
What about the Sapphire X800GTO2, is it Crossfire ready, before and after modding it? I have one on order...
Im not sure about before, but it should be.
It definitely is after flashing to an XT BIOS.
