symantec corporate because you can set up a server to manage the clients, idk if nod32 does this or not
NOD32.
Just make sure you get support with it... Can't remember if it has it or not.
A bad configuration can bring your network to its knees when NOD32 is scanning everything at once...
And be VERY wary with putting it on the server. I've had it lock up so tight (scanning or something- who knows... it was so locked up I couldn't do ANYTHING to find out what was going on) I had to hard reset the server.
Yes they have support.....and official support forums over at Wilders Security.
Never had it lock up a server (and that's a LOT of servers). But hopefully you follow standard exclusions when you're configuring any antivirus product on a server as soon as you install it.
I use this for a baseline...it's for SBS..but you can easily figure out which ones are vanilla server related, exchange, etc...and use it for other servers.
http://www.sbsfaq.com/Lists/FAQs/DispForm.aspx?ID=137
I did that.
This was with Version 3.0...... it was an SBS 2003.
Version 3 isn't compatible with Exchange. I made the same mistake with an SBS server as well, once. Even if you do set the exclusions it still screws things up for some reason. Uninstalled, rebooted, ccleaned it, installed 2.7 and all has been fine since.![]()
Exchange 2003 or 2007 or both?
I did that.
Eset couldn't give me an answer, either... All their answers involved "run this when it happens" or "check task manager", which when it is locked up like that- I can't do squat.
Odd thing is even my REMOTE stations started locking up (The server locked up all clients too... as soon as I unplugged network cable, freed them up), that aren't even joined to the domain.
At this point, almost too scared to give it another shot.
Ahh...no wonder it locked up....t'ain't compatible. Wrong product to install.
Need 2.7 for a box running Exchange. So that would include SBS.
I don't even put 3.0 on any servers....vanilla or not.....actually I'm still using trusty 2.7 for ALL clients..workstations...etc. 3.0 is fiiiiinally getting a bit better..but I still don't run it on my own rigs. I think it needs still a little more time to cook more in the oven.
We "might" see XMON 3.0 by the end of this year...but I'm certainly not rolling it out on clients right away....I'll wait at least...3 months after it's released..probably more like 6 months.
Any reason why 3.0 doesn't work???
Are you asking regarding servers or workstations?
Servers. My workstations are running fine![]()
I voted for Avira since it is free but if my work had the bucks I would definitely do a mass install of NOD32
