Which AGP Card?
Fons
I have a budget of $300 no more than that. I would prefer ATI but if the competition's not even close than never mind that. I'm also wondering if i should just wait for UT07 because I can run every game out there with my awesome 9600. So im kinda just looking for your opinions.
eVga or BFG or XFX 7800GS.
Or you can grab an x850xt.
read the stickied FAQ maybe?
You completely miss out on PS3.0 if you stick with AGP and ATI.
How big of an upgrade do you want? If you want the best get a 7800GS, but it'll cost you all of your budget. If you want something that is just better than your 9600, even a 9800Pro will be a good amount faster and you can find them used for real cheap.
Here ya go, slowest/cheapest to fastest/expensive...
9800Pro/XT
6600GT
6800GT/Ultra
X850XTPE
7800GS
what games do you usually play and at what resolutions?
What are the rest of your system specs? Putting an 7800GS on an Athlon XP would not be a good idea, I would hope that you have an P4 or an A64 of some sorts.
i have a barton and a 7800gs and it works OK
Right Now im playing Oblivion,War 3,UT04,BF2,Farcry and some older games.
My System
P4 Prescott 3.0 800Mhz FSB
ASUS P4P800 SE
2xCorsair Value Select 512MB
(Hope Thats a good enough description)
Edit-I was told i need to buy a whole new Power Supply if i get the 7800 GS
