Which AGP card is better?
ituggle
Trying to squeeze the last oomph out of an old(ish) rig. Help me choose an upgrade (to my ATI 9700 Pro).
ATI x800 xt 256 MB
or
XFX 6800 Xtreme 256 MB
I have a choice of either. Both are slightly used and within my budget.
Going into :
3.4 Northwood
2 gig of ram
Audigy2 ZS
any opinions appreciated!
Thanks
The X850XT will be much better than that particular XFX 6800 card. IIRC the 6800Xtreme was nothing more than just a 6600gt with 256bit memory and 8 pipelines, so a very crippled 6800 series.
'bout the same I think. Pick cheaper or go with your favorite brand. Nvidia usually has better drivers.
for 6800, get a gt or ultra
I can safely say that the X800XT has a tad slower performance than the X850XT, which has a lot more performance than a 6800GT.
If you are picky about SM 3.0, get the 6800GT or even the 7800GS if possible. If you want a better value, the X800XT will do nicely. I'd also consider the 6800GS.
I would personally get the X800XT. I have an X850XT PE (which is not a huge improvement over the X800XT) and I can testify that you could probably get some killer performance in newest games compared to your 9700.
I recently went from a BFG 6800GTOC which is faster than the 6800 extreme to a X800XTPE. Wow! What a differance. I mean they are close but with ATI you can crank up the eye candy with less effects on speed. I would go with the ATI, it may be older school but it still rocks. Just my opinion. Thanks.
I previously had a Oced, [ volt modded on both the core & memory 420/380] 9700 Pro card for three years and I just upgraded to the AIW X800Xt and just in its stock form with NO Oc it is more then twice as fast as the modded 9700 Pro.
IMO the AIWx800xt is the best AGP bang for your buck until you decide to upgrade. The Geforce 7800GS AGP may be a little faster and have the 3.0 shader, but these two nominal differences are not worth another $125.00 bucks !!!
Regards, Silverfox1
Seconded. A friend of mine has a 6800 Extreme and my 6600GT fares comfortably well against it, which is a bad thing for the former.
